3400 swap into 94 sunbird w/2.0
  • 3400 swap into 94 sunbird w/2.0
    I have a 1994 Sunbird with a 2.0 L MPFI 3-speed auto and would like to drop in a 3400. would like to know if anyone has done it and what I would need to do the swap. Can I use the same tranny? what motor mounts? Please help.
    well if hte 2.2 and the 3.1 have the same mounts
    then you should be good
    yeas you can use the tranny you will spin the tires like crazy though cause of the higer converter stall speed and the 3.18 gear in the differential
    I Like V660s
    Does Chevy make beer
    ~Jayme~
      You cannot use the 2.0L OHC tranny behind a 3400, and it has nothing to do with gear ratios or power handling, but has everything to do with the bolt pattern of the bellhousing.
      Mounts are also different.
        94s didnt come with 2.0 ohc motors they came with the 2.2 ohv
        I Like V660s
        ~Jayme~
          Recheck your info.
            my bad i was off by a year
            I Like V660s
            ~Jayme~
              Has anyone done the swap?
                Yes, a number of us have, check out www.domesticcrew.com/660 for genIII into J-body swap info, hybrid info and other information.
                  has anyone on here done a quad into a pre-90 cavalier?
                  91 GTP HM-284 GONE
                  96 Special Edition LQ1/4T60E GONE
                  98 Spawn of Satan (L67 Regal)
                  87 V10 SM-465/Mild 350
                  06 Cobalt SS/SC GONE
                    Pre-90? Not sure. But check out speedvisioncavalier at j-body.org, he's got a quad in a 2nd gen of some sort.
                    60v6's original Jon M.
                      the reason i ask is because im starting to plan a project down the road to build a turbo quad to put in an 89 or older since they only weigh 2300 pounds (supposedly). after 89 they got quite a bit heavier. i like the 90's Z24's a lot, but they're heavier than i want. i checked out that sight. its in a 91. thanks.
                      91 GTP HM-284 GONE
                        Shouldn't be that much of a difference in weight. 88-90 should be nearly identical.
                          FYI, the quad 4 will easily fit into any 82-94 Jbody. i have a 1991 cavalier with the 2.3, and i also have an 87 sunbird with the 2.3 also. it fits like it was made to go in there. just gotta weld in the tranny mount bracket and you are good.
