Questions for my swap
  • Questions for my swap
    Well in a few months I will be taking out my 2.8L and putting in a 3.4LCamaro/firebird) into my '92 S10 2WD. Here are some questions I have,
    I know that i have to use the oil pan from my 2.8 in order to clear the front cross member. but what oil pickup and pump do i use? I had heard I need to use the one off of the 3.4. But will it fit if i am using the 2.8L oil pan?
    also i am aware that the valve covers from my 2.8L will fit on the heads of the 3.4L. Is this true?
    Oil filter adapter? do i use the 2.8 or the 3.4 adapter?
    starter? will the starter from my 2.8L work ok on the 3.4? i am assuming it will considering they are pretty much the same engines. Also since I will be using my 2.8 flywheel it seems logical to use the 2.8 flywheel.
    now when reusing my 2.8 intake to put on the 3.4 does it fit perfectly? or are there some adjustments that need to be made?
    thanks for your help
    hmm i know that the 2.8 and 2.4 intakes are different
    but i think the heads and everything else are the same
    although i might be wrong since it is a different block
    not just a bored out 2.8 block you know
    I Like V660s
    Does Chevy make beer
    ~Jayme~
      Hmm I have herd these questions before. Didn't I talk to you on S-series.org? Anyway my site has the swap info on it. This site has a link to it aswell.
        are the heads on the 2.8 and the 3.4 identical? or are there differneces in the valves and stuff?
