3400/3500 hybrid conversion in rwd Grand Am
  • 3400/3500 hybrid conversion in rwd Grand Am
    I have a 3400/3500 hybrid I just rebuilt from my 3400 swapped grand am gt. Im converting the car to rear wheel drive, as the factory rear twist beam suspension will easily allow this. what rwd transmission do you guys think would be the best candidate? also will the engine mount brackets from the 3.4l block fit the 3400 if I tap some of the existing holes?
    the flywheel I have is from a 99 2.2l cavalier and clutch kit from a 94 cavalier v6. 9 1/8" diameter 14 spline, 1" input shaft
    below is the rear end of a rusty 92-98 grand am. not mine:
    auto or manual?
    you could try the 5 spd from a 3800 v6 camaro from the 90's or even a t56 if you wanted.
    auto, maybe the 4l60e
      manual. doesnt the t-56 use a different bell housing?
