EST Bypass Angle?
  • EST Bypass Angle?
    Hello,
    I want to verify the angle of the trigger wheel (internal) on my LX9 swap. What angle will the 3400 DIS module put out in EST Bypass? I'm seeing conflicting numbers in my search.
    Thanks
    When set correctly, timing at the crank will be 10* BTDC. The actual set-up of the sensor relative to the trigger wheel is not the same however, and IIRC the sensor will point at the leading edge of the notch for the #1 TDC when set correctly. The base timing is done within the module itself.
    This is why I make my crank trigger set-ups adjustable to set it correctly after the fact.
