3100/3400/3500 Engine management for Fiero
  • 3100/3400/3500 Engine management for Fiero
    Hey everyone. I've got an '85 Fiero 2m4 and am looking to do a 3500 swap.
    A bit of background:
    I originally had a '99 Monte LS that I swapped a 3400 into and turbo'd. That car was totaled. I managed to get a couple of parts back from it, sold some a while ago for cash to get me through not having a job for a month or two, but retained the ECU.
    SO! Here's my question:
    The PCM's Service number is 16236757, Hardware number 16200870. Will this run an early 3500 (non-VVT, non-DoD) or should I just sell it and get a 3500 PCM and call it a day?
    If that ECU ran the LA1 it will run the LX9. Nothing big in changes just that the LX9 doesn't have a low oil sensor
      You need an external crank trigger for a 3500 as well. The 3500 PCM can't be tuned.
      '86 Fiero, 3500, 4-speed
        would likely need to use the earlier DIS setup as well.
          The lack of a low oil sensor won't tell the ECU to enter a limp mode or anything? Only swap I've ever done was an LA1 into a '99 Monte LS, so you'll have to bear with me on the newer stuff if my questions seem stupid, as I haven't been in the loop for... about 6 years now.
          Does WOT-TECH still sell their 7x external crank trigger? And - when you say can't be tuned, do you mean not supported by HPTuners? Or do you mean the database section of onboard memory is read-only?
          Earlier as in...? Any part #'s or an idea of what donor cars I could yoink one from?
          Lastly - and this is probably a pipe dream (ahhah. hah. hah. No pun intended.), completely useless and an all-round terrible idea, but it's an idea, and I've got to ask. Long story short, in the future, I'd like to do a twin-turbo setup with two smaller turbos on this swap.* My thought was, rather than going with one large ceramic cat after the turbo, I could add a pair of pre-cat O2 sensors right off the manifolds, then a pair of the higher-quality metal substrate cats right off of that. Then up to the turbos, down to a crossover pipe, out to a resonator and muffler, then out the back of the car. This leads me to my question:
          Does the 6757 PCM allow for input from two precat O2 sensors? Or am I going to have to build a sum circuit that will take the input from the two sensors and convert them to a single output that the PCM can successfully read?
          *(GT25's, 60-trim or thereabouts. I don't have specifics yet, because this is still in the vapor stages. I want to get the engine in and running bone-stock first, then I'll worry about mods and forced induction later. Exhaust needs designed /now/ though, because I can't use the donor's exhaust.)
