Yeah, I know, it's been in there for like seven years. But I'm going to start fiddling with it again so that I can make my Trooper reliable before I dig into another car. I've been having an electrical issue, which I suspect is just a loose ground somewhere, but I liked how the Trooper felt with SFI and I want it back.
A few things are different from last time I had the SFI installed: I have a crane H260 cam, comp springs and 1.6 ratio rockers now (no cam sensor lobe). I would like to keep my mechanical fan, which won't clear the 3.4L intake - backup plan is to do what I did before, running two 10" fans mounted low.
I still have a full harness set up for the original 1994 OBD1.5 ECU, but I also have a harness made up for a '7727 (or whichever is the underhood version) which I had tested-started previously before I reinstalled my TBI (I wanted to get my Trooper back on the road for snowboarding season, but I always intended to return to MPFI).
I now have a variety of parts from 2.8/3.1 RWD that I may be able to use to make things fit better. I had them test-fit before I reverted.
Here are a couple old pics, I'll try to do better about taking pictures this time around...
