Seems I have a problem. I love the little platform that the chevette/acadian was built on. So I'm buying both kinds. I'm buying a 76 2 door acadian that will remain stock until the early 80's(unsure of year) chevette I'm also buying is done.
The 80's chevette has a complete drivetrain, 3.1L followed by a T5 5 speed with a custom rear driveshaft already made, It's a 98 monte carlo engine and the wiring harness has already been modified and uses a 93 cavalier computer(this is my main concern) the exhaust is complete. The owner says that the only thing it needs is a hydraulic clutch setup(he tells me one out of a 2002 s10extreme is what I need. I'm wondering if I can use the factory cable clutch. I'm sure small things like guages and fuel need to be buttoned up as well. I'm just curious about intake options. because I know on the fwd engines the throttle body is at the back of the engine.
