91 Z34 swapping in a LA1
  • 91 Z34 swapping in a LA1
    well I have 91 Z34 284 well I spun a rod bearing so the motor is toast but I have a complete LA1 sitting in my garage. I was thinking of putting that motor in so can drive the car while I build up my LQ1. Here's were I'm having trouble I know I can get the motor in and bolt it up with very little problems, but I dont know how the wiring would be. I want to makle sure that my factory computer can support the sensors and whatnot on the LA1 since this is going to be a kinda temporary swap. So if any one has any info or knows of a link t specifying the full swap it would be greatly apperciated
    68 El camino 454 speed muncie 3.90 posi 12 bolt,
    80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
    60 Impala 2 door hardtop L79-327 T56 4.11 posi.
    83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
    91 Z34 now has a hm284. and belly pan in the works
