3500 coolant lines?
  • 3500 coolant lines?
    swapping a 3500 into a fiero, need help with what coolant lines go where, anyone have some decent pics with descriptions?
    the coolant lines on the fiero, or on the motor?
      on the motor, so i know where i have to connect them :P
        non vvt is the same as a 3400 or 3100. top of water pump is lim and heater core. behind water neck is other heater core line. the waterneck is the upper and the one off the wp is the lower. idk if that helps.
