Help in a swap
  • Help in a swap
    I have a good block from a 3.1 out of a 93 lumina euro vin"t", I need to replace the engine out of my 89 beretta gt, a 2.8l v-6 vin "w". Does anyone know for sure if the swap can be made? The beretta has the 5-spd manual tranny.
    should be a no-shit direct swap except for maybe EGR.
      pretty much the same engine. Just bolt the 2.8 top end stuff on and swap the flex plate for your flywheel. Make sure to use the longer bolts from your 2.8 for the flywheel or you'll strip out the crank.
      you'll also gain about 20 ft-lbs of TQ and 10 HP.
