block differences
  • block differences
    I'm doing a v6 in my chevette, probably a 2.8 out of an S10. If I find a 3400 from a camaro later will it bolt up the same as the 2.8? I'm talking transmission and motor mounts, can I pull the 2.8 out and bolt the 3400 in without changing anything. If not, what needs to be changed?
    The 3.4 iron head motor out of a '93-'95 Camaro should bolt work but you would have to change intake manifolds if you plan on running a carb. Edelbrock makes a two piece intake for the 2.8 and you can run either a 2bbl. or a 4bbl. carb depending on which upper part of the manifold that you buy.
      As long as its out of the RWD iron head platform, no issue in changing out later.
      -BMC.
      MG & MGB V6 + V8 Engine Conversion Shop
      1982 Chevrolet S10 long box with another L32 SFI!
      1980 MGB with Camaro L32 3.4L SFI V6
      2000 Venture 3400 (for her)
      Spitfire L32 3.4L
      "Experimentals"
      and more conversions all the time.
