89 2.8L swap with 94 3.1L
  • 89 2.8L swap with 94 3.1L
    Hello everyone, had a question about putting a 2.8 L into a 94 Grand Prix with a 3.1L. The block is cracked on the 3.1L but I have a good 2.8L. My question is about the crank sensor. Can the crank pulley from the 3.1L be used on the 2.8L. Thanks
    Depending on where you live, it is actually against the law to install an older engine in a newer vehicle. And being a 94, you run into ALOT more issues with the computer than just the crank sensor. Best to just find a 3100 or even better, 3400, to swap in.
      Agreed. If the Grand am Used a 3100 than its it WAY easier to swap in a replacement or even a 3400 which will give you a boost in power too.
        Except for the 94 Cavalier and 94 Lumina, all 94 models got the 3100.
          There ya go. 3X00 FTW <first time I have used that acronym
            hehe, i have yet to use it!
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
