Who has completed a successful 3.6 swap?
  • Who has completed a successful 3.6 swap?
    I've read quite a few threads with people talking about it but they never seem to show completion. Anyone got one rollin?
    There was some guy with a sand rail that had one on here. Didn't get much info out of him. I think he had pics, I can't remember.
      So no others to speak of? What's the big hurdle with the 3.6 other than price?
        The engine is a little bulky, more rare than the pushrod motors and has a lot more complex engine control system.
          bulky as in bigger or heavier?
            Bigger for sure, DOHC motors are big. Heavier, probably somewhat.
              It's all aluminum externally so it certainly shouldn't be heavier than a 3.4 DOHC. I don't remember which thread but I do recall posting the weight. You have to decide what to do about the VVT which is a bit more complicated than the cam in block VVT motors though I'm sure you could find a way to fix them into an optimal position. Depends on what your plans are. All of the manual flywheels for it are dual mass I believe and your sources are likely the Saab 2.8L DOHC motors and the Cadillac CTS, in which case you would also have to use a Saab manual trans as a result or have a custom flywheel made.
                I've read that the LY7 weighs 370 lb installed. So how much do the others weigh (3.4, 3500, 3900)? As for the flywheel, if I pull an engine/tranny combo from a CTS why would I need to mess with it?
                  Because the Cadillac CTS is rear wheel drive.
                    So is my car
                      Sorry, didn't mention that before. 66 Sunbeam Minx. I posted another thread about it.
                        Mine is in process:
                        This is the manual transmission from a CTS being checked for fit in a Studebaker.
                        If someone has a link for overall 3.6L dimensions, it would be greatly appreciated.
                        1963 Studebaker Avanti: C4 Corvette narrowed front/rear suspension, C5 13" calipers/rotors adapted to C4, Viper differential with Intrax 3.54 ratio (the snake has been charmed!), coil overs, stainless tubular frame, stainless chambered side exhaust.
                        Here is a link to a slide show on the frame and car. Slide Show
                        Here is a link to the magazine article written on it: Magazine Article
