3.8/3.4 or 3.1 hybrid.
  • 3.8/3.4 or 3.1 hybrid.
    1
    Nothing will interchange from the 3800.
        boring and stroking, YES. As for actually attempting to put parts from a 3800 onto a 3.1/3100/3400 block, some have tried it and so far nothing can be used.
        I take that back. The fuel injectors fit.
        Taylor
        1998 Lincoln Mark VIII
          you can bore and stroke a 3500 to be a 60 degree 3800...
          Offset grind the crank +.25" then bore it out .030" and there you go.
          and Yes, i have a old 3.8 torn apart and have looked. It's completely different.
