Rippin out the 3100 what should i do next?
  • Rippin out the 3100 what should i do next?
    OK, so my 3100 that I have been putting miles on since I was 15 years old has finally come to the end of it's long tired and glorious life.
    My 1994 GrandAm is my first car. I have owned many cars since. But I LOVE this grocery-getter turned trophy-winner and I need a good show motor that will hold its own against some of the new import designs. I used to eat honda's for breakfast but now I can't seem to keep up with a 2008 si. I am tired of being all show and no go.
    I am pulling the engine soon and plan to repaint the engine bay and replace the wire harness.
    What engine's should I consider?
    What are the pros an cons of each?
    Has any one done this to this car before?
    Where can I get one already built, or performance internals?
    5
    New 3100
    20.00%
    1
    new 3400
    20.00%
    1
    new 3500GTP
    20.00%
    1
    3800 supercharged
    0.00%
    0
    northstar supercharged FWD
    40.00%
    2
    I would also like an engine with a manual transmission, but I am not against useing my
    stock tranny
      3100/3400 are kinda slow. 3500 is pretty good, 3800 is sh1t northstar is ultimate, theres a million northstars in my local junkyard.
        3500 swap with a 5 speed from a V6 Cavalier/Beretta should put you into the 13's with a good exhaust and tuning.
          has any one ever tried to put a northstar into a 92-98 grandam? it looks like it would fit, but i'm not sure if i will have enough clearance for the peripherals
            I like the 3400/3500 hybrids... 3800 weight a lot . 3400 is "basically" bolt in, 3500 is harder, and everything from that just gets harder. Never heard of a northstar swap, but heard of a couple S/C 3800s. I pesonally just like going the 3400 route because a lot of people have, so there is a lot of information out there on how to do it, and how to make them faster. But the best upgrade overall, in my opinion, is a 5 speed swap. The getrag 282s are easy to find, quite a bit of different gearing for them, pretty easy to get aftermarket clutches, and a lot harder to blow up than the autos.
              3400's arent slow by any meaning. mid 14's STOCK in a j/l body isnt slow at all really..
              [SIGPIC]
              12.268@117... 11's to come!
                how difficult is it to get a 282 into the grandAM? is it the tranny that came with the 2.4's?
                  http://www.bstuff.com/index.php?showtopic=56507 Just what berettas the 282s came in. With v6s and quad 4s
                  To get a 282 into a grand am is about the same as the cavis and berettas. Have to weld mounts in, put the shifter linkage in, etc.
