1999 3.4 into a 2004
  • 1999 3.4 into a 2004
    Hi guys, newbie here.
    I looked through the previous threads and did not see a like post.
    I have a 2004 3.4 that is bottom end damaged.
    I have acquired (for FREE!!) a complete 1999 3.4 out of a GA.
    First what I want to do is just use the short block and install my 04 heads, oilpan , accessories etc.... onto the 1999 S/B.
    Does anyone know of differences? The gasket kits are different (part numbers at least)
    OR other idea would be could I use the long block from the 1999 and just swap external accessories (oil pan, upper and lower intake, etc.....)
    The 1999 alledgely just needed lower intake gaskets (Oil/water milkshake).
    I would have heads checked etc....
    OR should I just get one from a 2004 from the boneyard, and be through with it.
    Thanks alot in advance for replies.
    Paul
    afaik it should work, i think the only diffrences on the 2 engines was the heads? (larger ports on the newers)
    altho, i could be compleatly wrong on this either way, free bump, im sure someone else will chime in soon.
