new 3.6 to a 700r4
  • new 3.6 to a 700r4
    Hi everyone I am looking for info on what it would take to hook a newer 3.6 DOHC motor from a cts to a 700r4 from an older 4x4 2.8 s-series.
    I know the bellhousing pattern is the same, but I am looking for info on flex plate , converter info.
    Thanks,
    Brad.
    Just use a CTS flexplate and use a 700R4 converter.
      nothing is ever that easy for me... is it really that simple?
        the fwd to rwd flex plates may be different. as long as they retained the smae crank bolt pattern (i see no reason for them to change it) a rwd flexplate would do the trick, just make sure it doesnt have a big weight on it (externaly balanced), as the 3.6 is internally balanced.
          The FWD and RWD diameters are different are they not? If you are keeping the 3.6L starter I think you need to use the FWD flexplate.
          There is nothing fancy about a flexplate. The just provide the starting ring and a place for the torque converter to mount. If for some insane reason a RWD converter wont bolt up Im sure it would only cost a bit to re drill it.
            thanks guys, I am searching for a trans currently then going after the 3.6.
            I have found out that that crank bolt pattern is differnt than the old 2.8 pattern so I will have to figure it out as I go.
