I HAVE A 1987 CAVALIER RS WITH A 2.8 i WANT TO SWAP A 1998 3.1 FROM A GRAND AM CAN ANYONE GIV ME DIRECTION ON HOW TO DO THIS?
need help
Isn't the 87's TBI?? If so, you might need to swap the harnesses to the 88-93 OBD1 harness or just swap to OBD2 if you want dhp. You'll need to fab up an engine mount I'm pretty sure. Other than that & swapping a few parts and making a few adjustments/alterations it should be straight forward.Lifting my front wheels, one jack at a time.
Originally posted by ForcedFirebird View PostIt's not an easy swap to put a FWD motor in the fbodies. The Camaro 3.4 is an easier swap.
Check out www.domesticcrew.com for probably the best writeup on this swap.-Brad-
Originally posted by bszopi View PostIt must be too earlier for you to be posting, cause nowhere in that thread do I see any mention of an F-Body. Last time I checked, an 87 Cavalier was a J-Body.
Originally posted by rlue View PostI have the whole 1998 Grand Am so I can use the wiring out of that if it will work. Will the Tranny from the Grand Am fit in the Cavalier it may be a fourspeed auto?
Ok you need to do more research. You seem like you have NO idea what you are doing (dont take it the wrong way) . You'd hate to take apart a running or easy fixable car then in the end have to junk it and the donor car because it is way above your head.Lifting my front wheels, one jack at a time.
