throttle body size
  • throttle body size
    does anyone know the difference between a 2000 malibu 3100 throttle body size vs a 96 grand am 3100 throttle body size? any help would be appreciated. thanks
    56mm vs 52mm
      Is this for sure Brad? Someone on here told me even the large port 3100 was still 52mm.
        Possibly. I thought that when the port size was upgraded, so was the TB size. But, I could be wrong...
          Me too but someone said other wise... So IDK.
            Large port 3100 should be a 56mm also
            02 GTP - 90* > Failboat
            www.blackbombshell95.com
              the reason i ask this is because i have my small port 3100 engine and trans out of the car.
              i was planning on rebuild another 3100 with the big port intake, but i need this car running quick because my other grand am is on it's last legs. very faithful though.
              unfortunatley, now that i have the engine and trans out, i've now discovered the lower intke manifold has been pissing oil. so, since i have to pull the intake, i might as well do the swap from now.
              the only problem is the 3100 big port upper intake's throttle body looks EXACTLY the same size as my 3100 small port, except the linkages are different. if i didn't know any better, i could pull the small port throttle body and bolt it right to the big port upper intake. everything looks exactly the same except the linkages.
              i figured with so may swaps going on someone would know for sure. i have measured them yet, but man they look close.........
                They will bolt up no matter what, so if its a rush rush thing, just put on your old one and figure it out later.
                  i may just have to do that. thanks though........
                    Just for clarification, the 2000+ LG8 (3100) engines still received the 52mm TB. I'm quite sure of this, as I once attempted the 3100 big port manifold swap on my '95 Beretta, and noticed they Tb's looked identical as well. So I picked up a 3400 TB just to see.....and you could visually make out the difference
                      Yes, my sister's '02 GP with the 3100 had the 52mm TB. The plenum opening is over 56mm however!
                      Brian
                      3400 SFI V6, 4T60e
