which one
  • which one
    Ok I decide that I am going to build a motor for my Beretta but I am not sure which one to start with If I get a 90-93 3.1 could I put the flat top pistons for a 2.8 that summit has. I know they have the same bore but are the wrist pins in the same place also would like to get a cam mill heads what should I do for the top end which heads would be the best.
    the wrist pin is in a different location with relation to the top. It won't work. However you can use the 3.1 pistons meant for the iron headed engines (Camaro etc) they're not flat top but less dish area than your stockers, if high compression is what you're looking for.
    Brian
    3400 SFI V6, 4T60e
      I am looking to raise compression I want a motor with good streetablty but that will run mid to low 16s in the ¼ mile I plan on doing a 5 speed swap at the same time
        Bone stock 3.1 with a 5 speed should get you high 15s with ease.
          i was gettin 16.42s in my 88 beretta 2.8 5spd with exhaust and suspension
            ok so I decied what i am going to do I am able to get a 92 lumina 3.1 motor for cheap so I am going to use pistions with less dish than the stock ones crane cam not sure which one yet CAI and dual exhust
