Swaping 94 Camaro3.4 into 86 Fiero V6SE
  • Swaping 94 Camaro3.4 into 86 Fiero V6SE
    Do I need any parts from the Fieros 2.8 or will the 94 Camaro engine just bolt up to the fieros existing transmission.
    Thanks
    Yes and yes.
    I believe there are better explanations on this or pennocks or any number of sites to explain this than what I could give.
      you need to redrill the starter holes to the correct side of the block. you will need the fiero intake manifold, timing cover, distributor, and accessories.
        nolonger considering the camaro engine.
        Went with 3100sfi thanks.
          The GM mini van 3400 is a good choose for the fiero. That's what i'm using with some mods and vortech V1 supercharger..
