Dead DHP interface?
  • Dead DHP interface?
    how can you tell if you've killed your DHP interface?
    I'll start with the question of what is making you think you killed it? what did you do, what is it doing/not doing....
      Cross posting this from my build thread:
      no idea, working fine one minute, won't connect the next... I'm going to try and get a new serial-USB adapter and try that and see if it fixes anything...
      Yeah if it's just connection issues I'd try swapping out the usb/serial adapter as well as check the config on the PC make sure the com port number didn't change or something. Does the light still blink on the unit? If so it's a good sign that nothing is wrong with it.
      light does still blink. I tried changing com ports(and the USB port used), as well as connection speed, nothing seemed to change the results.
        turned out to be the USB-Serial adapter.
