99 Malibu bin file?
  • 99 Malibu bin file?
    does any one have a 9377739 bin file for 99 Malibu with vin and id still intact so I can edit with TT or can someone help with adding a vin and id to a bin file with vin removed?
    tinytuner doesn't need the VIN intact...
      I cannot get TinyTuner to add the VIN and ID to a bin file with the VIN removed, the options are grayed out.
        Download a hex editor and manually enter the VIN.
        2000 Grand Am GT
        2011 Chevy Impala
          Do you know what info & where to enter the info? I have a bin file but missing vin & id so I don't know what and where to enter.
            I was able to locate it doing a search in the Hex editor.
            VIN Location in many PCM's is located at 00004000 - 00004020
            I successfully swapped over a 2000 VIN to a 2004 .bin file.
            2000 Grand Am GT
            2011 Chevy Impala
              Do you use hptuners or dhp?
                I tried entering the VIN and ID at 00004000 like you said and now the car will not stay running and HPtuners doesn't see the vin any more. Can you give me a little more information about adding in the vin info. I don't have any sample bin files to work with.
                  I use HPtuners, so I do not have a way to get a bin file myself.
                    PM me with your OSID and VIN.
                    I will see if I can get the file setup for you.
                    I have both DHP powrtuner and HP Tuners
                    2000 Grand Am GT
                    2011 Chevy Impala
                      I sent pm with info.
                        Here is a copy of the .bin file with the requested VIN and VCM ID.
                        2000 Grand Am GT
                        2011 Chevy Impala
                          Thanks for your help, I appreciate it.
