Injector Change
  • Injector Change
    I am completing a 3400 build in an 2005 Impala, and will be switching to the Injectors from a 2002 Trailblazer.
    2005 Impala -
    22.5lb/hr injectors at 370kPa or 236.25cc/min at 53.7PSI
    2002 Trail Blazers -
    28lb/hr injectors at 410kPa or 294cc/min at 59.5PSI
    Using the Impala's pressure, I get
    278.91cc/min or 26.54lb/hr
    Yielding 15.22231% increase
    Is there anyway to easily adjust the Injector settings with HPTuners?
    2005 Impala -
    23.5 to 25.5 IFR depending on your altitude and other factors. That should get it running, anyway. They functioned well over a fairly broad range of fuel pressures for me.....
      ty sir
      Edit: As far as Altitude goes - I'm in FL so, assume Sea Level.
        Using the HPTuners VCM Editor, open your configuration file.
        Go to Engine - Fuel Control - General.
        Under Injector Control, select Flow Rate vs. KPA.
        Make sure you take note of the units displayed -
        If you are showing lb/hr, set all values in the table to 26.37.
        If you are showing g/sec, set all values in the table to 3.32.
        Save the file witha new name (do NOT over-write your stock file) and flash it to your PCM.
        Matt
