Today I did some driving and scanning with HPtuners. Is it normal to have absolutely zero KR and also my map kpa stayed at 10 kpa both key on and running. Maybe bad sensors or I have a huge vacuum leak? It did exhibit a slight stumble at tip in. This is on a 3500 with a 3400 upper/tb and 28 lb injectors running at 62 psi. So far I think I have the fuel injector flow set right and I copied in a 3500 ve table.
I used the default configuration in the scanner app. Is there any special configuration needed for our setups?
thanks in advance and sorry I have no datalogs right now. I'm on my linux desktop, my laptop is with the car 40 miles from here
