wiring help needed!!
  • wiring help needed!!
    im installing a 3500 into my fiero, and using a 98ecu, i have most of it figured out and compleated, so the first problem/question i have is the knock sensors...
    are the new knock sensors compatible with the 98ecu? if so, how would i wire them?
    looking at the diagram theres a twisted pair, then a 3rd wire thats labeled as "drain"
    im assuming if they are compatible the drian would be a pcm shared ground, the 1twisted would be 5v ref, and the other the signal wire?
    next question... are the cam sensors compatible from the 98ecu to the 06 engine?
    No the KS are not compatible.
    Not 100% on the cam sensor, but I am pretty sure that it will work.
      im running a stock 05 3500 non vvt cam sensor with my swap and im running on 99 grand am pcm and modded harness. never had a problem, also running 3500 cts, and map
