I am tuning a 3.4 DOHC with the L67 injectors. I have set the pressure to 55psi with the key on, engine off. I hope this is the correct way to go about it.
Currently the fuel table is 36.10 rate across the board. The Stock 98 GTP uses a rising fuel rate with kpa, which makes sense but I am not sure if their rate increases more than an NA engine will. Oddly enough the stock 97 3800 code I downloaded was 38 across the board...strange.
I have other questions but I already know I have a LOT to learn with this system. Wish I had the time like when I learned OBD1.
