i am doing a 3100 swap out or a 98 chevy lumina in to a fiero and i need the ecm pinout. any help would be great.
3100 ecm pinout
Hi
Blue pcm connector (C1)
Pin
Wire Color
Circuit No.
Function
1-2
Not Used
3
ORN
55
Fuel Level Output Control
4
LT GRN
1222
Shift Solenoid A Control (1-2 Shift Soleniod Valve)
5
DK BLU
473
High Speed Fans Control
6
DK GRN
335
Low Speed Fans Control
7
BLK
630
Camshaft Position PCM Input
8
PPL/WHT
430
3X Reference
9
LT BLU/BLK
647
18X Reference
10-14
Not Used
15
TAN
800
Serial Data (UART)
16
BLK/WHT
451
PCM Ground
17
BLK
808
Sensor Ground
18
Not Used
19
PNK
339
Ignition Positive Voltage
20
ORN
540
Battery Positive Voltage
21
Not Used
22
PNK
1224
Transmission Fluid Pressure Switch A Input
23-27
Not Used
28
TAN/WHT
1669
HO2S Sensor 2 Signal Low
29
TAN
413
HO2S Sensor 1 Signal Low
30
PPL
420
TCC Brake Switch Input
31
Not Used
32
GRY
435
EGR Control Ground
33
DK BLU
496
Bank 1 KS Signal
34
LT BLU
1876
Bank 2 KS Signal
35
Not Used
36
BRN
25
Charge Warning Indicator Control
37
Not Used
38
LT GRN/WHT
1749
IAC Valve B High
39-43
Not Used
43
YEL/BLK
846
Fuel Injector #6 Control
44
YEL/BLK
1223
Shift Solenoid B Control (2-3 Shift Solenoid Valve)
45
Not Used
46
LT BLU/BLK
844
Fuel Injector #4 Control
47
BLK/WHT
845
Fuel Injector #5 Control
48
RED/BLK
453
Reference Low
49-52
Not Used
53
TAN/BLK
424
Bypass
54
WHT
423
Ignition Control (IC)
55
DK GRN
389
Vehicle Speed Signal Output
56
BLK/WHT
451
PCM Ground
57
BLK/WHT
451
PCM Ground
58
Not Used
59
PPL
1807
Class 2 Serial Data
60
BLK/WHT
451
PCM Ground
61
Not Used
62
DK BLU/WHT
1231
Automatic Transmission Input (Shaft) Speed Sensor (AT ISS Sensor) Low
63
RED/BLK
1230
Automatic Transmission Input (Shaft) Speed Sensor (AT ISS Sensor) High
64
YEL
400
VSS High
65
PPL
401
VSS Low
66-67
Not Used
68
YEL
772
Transaxle Range Switch B
69
YEL
492
MAF Sensor Signal
70
DK BLU
229
Theft Deterrent Fuel Enable CKT
71
Not Used
72
DK GRN
83
Cruise Disable/Inhibit Control
73
LT GRN/BLK
1745
Fuel Injector #2 Control
74-75
Not Used
76
DK GRN/WHT
428
EVAP Canister Purge Control
77-78
Not Used
79
BLK
1744
Fuel Injector #1 Control
80
Not Used
Clear PCM Connector C1
Pin
Wire Color
Circuit No.
Function
1
Not Used
2
WHT
1310
EVAP Canister Vent Valve Solenoid Control
3
DK GRN/WHT
465
Fuel Pump Relay Control
4
RED
1676
EGR Valve Control
5
BRN/WHT
419
MIL Control
6
BRN/WHT
1173
Low Oil Lamp Control
7
LT BLU/WHT
1747
IAC A High
8-9
Not Used
10
PPL
412
HO2S Sensor 1 Signal High
11
PPL/WHT
1668
HO2S Sensor 2 Signal High
12-15
Not Used
16
WHT
776
Transaxle Range Switch P
17
RED
1226
Transmission Fluid Pressure Switch C
18
BLK/WHT
771
Transaxle Range Switch D
19-21
Not Used
22
LT GRN
66
AC Request
23-24
Not Used
25
LT GRN
432
MAP Sensor Signal
26
YEL
410
ECT Sensor Signal
27
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
28
BRN
1456
EGR Pintle Position Signal
29-32
Not Used
33
GRY
416
5 Volt Reference A
34
GRY
474
5 Volt Reference B
35
Not Used
36
GRY
803
Change Oil Lamp Control
37-38
Not Used
39
DK GRN/WHT
459
A/C Compressor Clutch Relay Control
40-41
Not Used
42
PNK/BLK
1746
Fuel Injector #3 Control
43
Not Used
44
LT BLU/BLK
1748
IAC Valve A Low
45
RED/BLK
1228
Pressure Control Solenoid High
46
LT BLU/WHT
1229
Pressure Control Solenoid Low
47-48
Not Used
49
LT GRN/BLK
444
IAC Valve B Low
50
TAN
472
IAT Sensor Signal
51-54
Not Used
55
DK GRN
890
Fuel Tank Pressure Sensor Signal
56
GRY
773
Transaxle Range Switch C
57
DK BLU
1225
Transmission Fluid Pressure Switch B
58
BRN
1174
Engine Oil Level Switch Input
59
WHT
85
Cruise Status
60
Not Used
61
RED
225
Generator L Terminal Control
62
Not Used
63
YEL
657
Transaxle TCC Release Switch Input
64-65
Not Used
66
DK BLU
417
Throttle Position (TP) Sensor Signal
67
Not Used
68
YEL
1227
Transaxle Fluid Temperature (TFT) Sensor
69
PPL
30
Fuel Level Sensor Input
70-77
Not Used
78
BRN
418
TCC PWM Solenoid Control
79-80
Not Used
