Educate me on 02 Sensors
  • Educate me on 02 Sensors
    Im going to replace my 02 sensor on my new engine since i totally raped it while trying to get it out. I heard some things about 'wideband' & 'narrowband' sensors... Whats the difference? Witch do I want? Any other usefull 02 sensor info welcome.
    you use wideband for tuning purpose. more accurate.
    correct me if im wrong but isnt the stock form a narrowband.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
      Yes narrow band is what the ECM uses.
      Wideband is for tuning, as it's much more accurate/wider range of viewing the AFR. Some Widebands come with a narrowband conversion output box thingy for the ECM and you can run one O2. But I've heard widebands do not last that many miles so it shouldn't be your main O2.
        As geldartb said, you would use a wideband O2 sensor when you want to get serious about your tune. It's considerably more accurate and has more AFR range than the stock narrowband sensor. Your narrowband sensor is limited to just 14.7 AFR. Most wideband sensors can handle a range from 9 to 16 AFR. One thing to keep in mind is they are not directly interhangable. Yes they both fit the same O2 bung, but they run on different voltages. Narrowband range from 0 to 1 Volts, while wideband range from 0 to 5 Volts. Thus your PCM won't recognize a wideband sensor unless the controller for that sensor has a simulated narrowband output. This would have to be hard wired in place. I don't know of any places that make plug and play kits for this.
        Your local OBDII moderator
        2000 Grand Am GT w/ WOT parts
          isnt there a wideband that has narrow band output too?
          2012 Chevy Sonic Turbo 6spd
            And then there's the AC Delco vs. Bosch topic...
              There is no wideband sensor that has a narrowband output. Instead the controller for the wideband sensor can have a narrowband output as well as the wideband output. The LM1/LC1, UEGO and PLX controllers can all do this.
                Yeah im just gona go with a narrow band. The wideband seems like alot of work and sure maybe if it was a plug&play but im just gona get the car running before i start adding a bunch of stuff
                ??? Id prob get the acdelco unless its like really expensive or somthing..
                  After AC Delco I'd say go for Denso. Sparkplugs.com has good prices.
                    X2
                    Stay away from Bosch for narrowband sensors. GM PCMs don't like them for some reason.
                      Not to burst any bubbles but gm DIS doesnt like bosch platinum plugs either :S.
                        We know this! lol
                          I have Bosch.
                            So, if I may digress slightly: I have new Bosch HO2S (AC Delco would have cost $100 more for the pair, and I didn't know better), what symptoms might I be experiencing? Will they die young or will I run rich and get bad mileage or what?
                              The complaints run from rough engine operation to hard starting to poor gas mileage.
