I decided to post a new thread about my OBD2 swap for my 1988 Cutlass Supreme.
Most people seem to be doing the OBD2 swap to like 1994-1995 cars that are already SFI, so the wiring is minimal at best. You have to add in some wires, but for a 1988 car, you have to rewire the whole car.
I figured I would show pics of mine seeing that I want to fully document this and for future refrence for those that might decide to do this to their 1988-1993 cars.
Well..... After I blew up the engine in my gold car (1988 Cutlass Supreme with the 3100 MPFI, 4T60-E), I have not been able to get it to run right after I fixed it. I have done everything that I can think of all to no avail. Time to pull out the big guns.
I am doing an OBD2 swap. I started it today. I started pulling the old wiring out, but the way it is twisted around in there, I think I am going to have to pull the engine out just to get the wiring out. No big deal seeing I have to pull the engine out anyways to swap out the tranny (replacing the 1993 4T60-E with my 1996 4T60-E).
I am going to have to do a lot of interior wiring as well. I have to add in the pass key shit, so since the dash has to come out, I am going to do some isolation and padding to help get rid of the squeeks and rattles.
I got about half of the wiring out today, but I think I have to start getting the engine apart to get the rest out. Seems to be routed under the engine, then next to the tranny. No biggie.
I am going to try to REALLY document this in case others decide to go the same route later on.
time for pics:
This is all of the new 1996 wiring pulled straight from my wrecked 1996 Grand Prix. It is all of it from the C100 firewall connector, to the passthrough under the brake booster. I also have both of the fuse blocks. I am not sure how extreme I am going to go with this, but in the worst case senario, I can go ALL OUT.
This is the new PCM and the 3100 ALT. I also have the spare ECM for my 1990 Grand Prix in there, but the silver one is what is going in my gold car.
This is all of the wiring out of the ECM area under the coolant resevoir. I removed the stock ECM holder seeing that I can't use it for the newer PCM. I will also have to try to use the newer COOLANT RESEVOIR.
More of the wiring coming out.
And last of all, these pics show why I don't like the OPTIMA BATTERIES. I had one EXPLODE in my car, and the dry cell shit in there caused this damage to the hood.
And if you look to the right of that big ratchet, you can see that the side is all flakey and messed up as well. I am going to have to get some paint on there before it starts to REALLY rust.
time for pics:
