TunerPro RT V5 connection issue
  • TunerPro RT V5 connection issue
    Could someone give me some pointers on how to trouble shoot this problem?
    I have been working with Ben developing a tune for my L-32 hybrid. Everything was progressing well when for whatever reason I lost the ability to communicate with TunerPro. What occurred is this. I would receive a new bin, burn a chip, install chip, log the results and return data to Ben. Nothing unusual there. Then I receive the latest bin. I burned a chip, installed it, startup TunerPro and nothing. No data transfer. I re-installed the previous chip and bin and everything worked. Went back to the latest chip and nothing. I switched back to the previous chip/bin again and this time nothing.
    I have tried and checked a couple of ALDL cables, confirmed drivers, tried 2 different laptops (one w/windows 8.1 & one w/ XP) and checked all connections with no luck in finding the problem. Any ideas?
    Ed
    Ed
    bad chip.
      I thought possibly the same thing. I tried another chip with the same results.
      Ed
        Is your CEL also on while running with this bin? If so, you're in LHM (Limp Home Mode).
        Sounds like a corrupted bin, it happens occasionally, especially if the checksum doesn't get updated correctly for whatever reason.
