setting up a wideband through EGR for OBD1
  • setting up a wideband through EGR for OBD1
    Was there a patch for A1? I never did this so I don't remember what it takes to make an Innovate LC1 or any other wideband work through scanning in tunerpro. Searched...didn't see it but it might be buried in a thread about something else. Did see the tuning article on here is outdated now though:P
    I think I use one of the A/C inputs for my wideband signal. No patch needed just need to edit the adx file
    '86 Fiero, 3500, 4-speed
      I don't know how to edit the ADX file and do anything productive. If thats all it is, we should be able to have files for using EGR, and any other possible inputs. That or maybe an article on how to make it work for whatever, but I have a feeling most people don't want to deal with that. DL and done.
        the wideband through a/c pressure is pretty simple since a/c pressure is already reported in the datastream. just an edit to the ADX or an alternative ADX would work.
        EGR position is doable as well, but requires a patched BIN and modified ADX, IIRC.
          That's something that would make or atleast help tuning a lot easier. Interested in setting it up.
          Sent from my iPhone
          3400/Getrag 284 5spd
          350/NV3500 5spd
          2014 Chevrolet Malibu LS
            Ok it is the AC input not the EGR. Pin C21. So, with that, its just an ADX edit? Care to show me how? I uploaded whatever A1.adx I have. Id guess you wrote this;P I sure didn't!
              wow, it's been a while since i've looked at stock A1......
              anyways, the A/C pressure sensor value is completely unmodified from what the PCM sees, so what gets reported over the datastream is actually raw voltage, tunerpro converts it to pressure(or in the case of a wideband, AFR/lamba/etc)
              with tunerpro open:
              Acquisition->edit definiton
              open the values category on the left
              scroll down and find A/C pressure........ and it doesn't exist. :/
              well, i guess we're not modifying A/C pressure, we're adding it in. or, could grab a better ADX(the flags actually look kind of bare in this one), the A140 ADS on the TP site can be imported and the mode 1 reply body size fixed for ADX conversion.
              Add New Item
              give it a title and unique ID
              find out through some voodoo that A/C pressure uses a packet offset of 32(decimal)
              click over to the conversion tab
              here is where if the A/C pressure value already existed, it would pick up.
              now, the equation used will depend on the controller. the easiest way to explain it is that it will look like this: (X*??)+?
              the ? is the lowest AFR/lambda value that the wideband controller pushes out(for a lot, this seems to be in the 7-9 range), in other words, the AFR that is represented at 0 volts, the ?? is most easily described as:
              (maximum AFR displayable - minimum AFR displayable) / 255
              for example: 8-22 AFR range:
              (22-/255 = .055
              alternatively, you could create a lookup table, insert the minimum AFR for the 0 input value and maximum AFR for the 255 input value.
              at that point, you're pretty much done. if you added the item rather than modifying the A/C pressure value, you'll need to add it into the item list view to see it that way, otherwise it is only visible in dash and monitors view. item list views->default view(or whatever you have), insert item and find the value.
              now it's done.
              i attached the A140 ADX with the 8-22 range conversion in it, modify as necessary, set up minimum/maximum alarms/etc.
                Wow. I have a lot to learn because I barely understood any of that.
                Sent from my iPhone using Tapatalk
                  well, what did you understand? what was most confusing?
                  i know i like to throw a lot of words together, sometimes to the detriment of everyone who isn't me.
                    Lol. I know very little about tuner pro or tuning period. I pretty much just understood the formula you were explaining
                      well, if you open tunerpro RT V5, you should be able to follow along, i don't think i skipped anything.
                        Pretty excited that tuning a GM is so much easier than let's say the BMW's I've had or the Toyotas. With Toyota your options are. Piggyback or standalone.
                          Actually, your Malibu being a 2003 will use HP Tuners for tuning, Tuner Pro is for OBD 1 cars and HP Tuners is for OBD 2.
