bhak disassembly - rev limit routine
  • bhak disassembly - rev limit routine
    working with DF
    im trying to figure out the routine that calls address 00BA-00C6
    which is the... "RPM THRESHOLD TO FORCE F31 TRANSMISSION UPSHIFT VS. STARTUP COOLANT TEMPERATURE"
    to have it jump that "call" to bypass that so i can then control shift RPM via rev limiter
    i must admit im NOT good at hacking dissasembly...
    i've done some digging and will share what i have found, soon
    but would loooove some input and a point in the right direction
    i wouldn't call it a rev limit routine... but this may help you.
