disabling egr in $8f code w/tunerpro
  • disabling egr in $8f code w/tunerpro
    I cant remember exactly what it was called...I remember it having to do with the coolant temp?? I used the item finder and had no luck
    '94 Cavalier Z24 3400 Turbo 5 spd
    If Coolant <= This, Disable Egr
      are you using my 8f.xdf ?
      facking tunerpro just messed it, and i think it may be messed up in the 1.1 i uploaded grrr
      is it kinda messed in the top
      should start out with
      A/C
        I can't find any reference to "Disable EGR" in any 8F definition I've seen.
