Hi guys...
Just an FYI, I am working on an ECM test bench. What does it do? Well, it allows you to simulate all inputs to most ECM's. You can test ECM's, trace down problems, test your own code, etc.
Features will include:
Lights for:
-Injectors
-Fuel Pump
-Fan 1
-SES
-Shift
-IAC
-TCC
-EGR
-Can Purge
-Air Select
+4 extra to play with
Digital Inputs:
-Ign PWR
-Switch for A/C clutch on
-Park/N switch
-Power steer switch
-Diagnostic switch with 3 position select resistances. (for ALDL)
-4? extra switches for whatever
Analog/Controlled Inputs:
-RPM
-VSS
-TPS
-MAP
-CTS
-IAT
-KNOCK
-o2 simulator
-FP voltage Input (adjustable 6-12V)
-3 additional pots for extra inputs
-Onboard RS232 coms
Most current estimated cost for parts and board will be around $100. Will vary depending on how many boards I order, and if I get a group buy for parts. I just need a headcount for people who would be interested. This WILL be put together whether anybody here is interested or not. Please only speak up if you are 90% sure you would purchase one if available in the next month or two. (There is no commitment, but I don't want to be stuck with 50 extra boards
)Thanks,
Lights for:
-Injectors
-Fuel Pump
-Fan 1
-SES
-Shift
-IAC
-TCC
-EGR
-Can Purge
-Air Select
Digital Inputs:
-Ign PWR
-Park/N switch
-Power steer switch
-RPM
-VSS
-TPS
-MAP
-CTS
-IAT
-KNOCK
-o2 simulator
-Onboard RS232 coms
