Tuning 94 Grand Prix ?'s
  • Tuning 94 Grand Prix ?'s
    I have a 94 Grand Prix Gt, That I am wanting to do a lot of engine work to, My question is, Is the PCM capable of being tuned?
    What software and hardware will I need, and if not is there an alternative PCM setup i can use?
    Thanks for any advice you may have.
    1999 Grand Prix SE 3100
    1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
    1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
    The 94 ECM cannot be tuned unfortunately. Its a bastard OBD1 setup that is flash, so you would either have to use an older ECM or a newer OBD2 computer to be programmable. That or aftermarket.
      Thanks Ben, Thats what I had found out after a bit of research.
        who tunes the 96 computer? and can they make it work for a manual tranny
          Has anyone here done a OBDII swap into a 94? Or know of any articles discussing this?
          It can not be that hard to do.
            It's possible to swap a manual and have it run on a 94 ECM. Just have to connect some wires so the engine starts (park/neutral switch), disconnect one (auto locks), and make sure the drive selector is selected (so you rev past 4,000rpm).
            ODBII swap info: http://www.beretta.net/board/ib3/iko...t=ST;f=9;t=225
