Help with ecu file?
  • Help with ecu file?
    Hi, I'm new to tuning and I was wondering where to find an .ecu file for a 90 lumina chip. I looked at the eeprom and it had AUMX 1249, which I found a bin file for. It also has 6J0134 and delco J733. What is the A1, 6D, 88? I'm confused, I understand that they are different layouts, although do I just pick one or is there one particular for my vehicle? So I have the winbin setup and the bin file if that is right, which ecu file do I use and where do I find it.
    thanks
    aric anderson
    what ECM? the 7727?
    Okay now, that's enough of that.
      where do I find that? Here is the info from the bin lookup:
      Broadcast Code Year Release Date EPROM
      AUMX 1990 1989-12-12 16151248
      ECM Prom ID Scan ID Platform
      16197128 1249 1301 WB
      Engine Displacement Transmission Transmission Type
      LH0 3.1 ME9 AUTO
      Gear Ratio Emissions Contributor Get Bin
      Aumx1249 5F.bin
      ecm 16197128
        90 code is 88 mask. If AUMX is 5F, its for the MAF sensor and there isn't much you can do for tuning that other than tunercat (maybe). I would go with the update chip to remove the MAF from the engine.
          do u mean the mass air flow sensor because I don't have one? All I have is a map sensor and the iat. I was just trying to disable the egr.
          thanks
          anyways
          aric
