Tuning OBD1.5 for boost
  • #16
    okay, what about a piggyback system that can be tuned with a laptop?
    need to know what and how much
    • #17
      I have a Split Second FTC1. It is tunable by laptop. They run about $550. Mine modifys MAF and timing based on RPM and a built in MAP sensor. If you're not running a MAF, there are other options out there.
      Tim
      325 whp 350 lb-ft
      • #18
        sorry didnt see your post till just now, the swap itself takes about a day, theres some research involved and some time required to prep the doner harness for the install.
        I would give you an excat price and parts list but it varies by the car. What I listed above are some of the main things you will need.
        If you need help making it work I can help you with whatever info you need. Be prepared to spend some time studying wiring diagrams and such.
        1995 Monte Carlo LS
        3400 SFI 60v6
        • #19
          so about how much should i expect to pay for wiring harness?
          • #20
            Call a junkyard. I'd expect an engine harness to be in the $50-100 range. I got $70 for mine, minus the fan connectors.
            • #21
              yeah I paid about $110 for mine, youll also need the PCM, injector harness, knock sensor, new trans position switch sensor, temp sensor and a couple other things.
              1995 Monte Carlo LS
              3400 SFI 60v6
