I'm still having problems with getting a good tach signal. I was brain storming last night and remembered that there was a metal lip that ran around the reluctor, so the mounting tab stood ~1/16" from the block. I couldn't get the reluctor to sit any closer, no matter how I rotated it. Nevertheless, I bolted it in and forgot about it. Could this tab be the cause of my intermittent tach signal? The reluctor was brand new when installed. I retwisted the wires and added a SS shield/ground wire soldered to the ignition module side (NOT terminated on the reluctor).
Should I grind off the reluctor tab? I'll probably need to take the engine out of the car to reach it.
