3.1 stalls only when coming to a stop
  • #16
    fuel is good , has spark, no codes, and it wont fire????
    • #17
      It has fuel to the rails... there could be an issue with the injectors.
      • #18
        good point, aside from checking to see if a couple of plugs are wet after turning over, how else can i check?
        • #19
          so ,the saga continues, i go out to turn it over and pull a plug afterward to see if it's wet or not and the freakin car starts right up. still no codes, ran it for 15 minutes and shut it off disgusted. it still "surges" when you open up the throttle, let off a bit and it's fine? also only in park, not in gear?pulling my hair out- help!!!!
