3400 PCM harness connector dissassembly ?
  • 3400 PCM harness connector dissassembly ?
    Does anyone know how to get the back shell off the PCM harness connector? There are two squeeze tabs on the end of the connector shell but something is hanging up in the middle near the jack screw.
    I need to swap some pin locations to adapt the harness to the PCM I will be using.
    I think you have to force out the bolt.....
