How do you reset an OBDII ECU to make it relearn
  • How do you reset an OBDII ECU to make it relearn
    Title says most of it...how do you reset an OBDII ECU to relearn driving habits and idle?
    Does resetting codes also reset the above?
    http://www.cardomain.com/ride/390342...evrolet-camaro
    It doesn't really learn driving habits and I am not sure there is a relearn procedure for idle other than driving the car and letting the fuel trims get sorted out if that is the issue. It doesn't self tune other than fueling, which is reactionary, meaning not the best results.
      yep what ben said. but if you still want to go ahead and wipe its memory, pull the battery for about 30 min to an hour. that will do it.
        I pull both battery cables, jumper them together, and KOEO for 10-15...then, I found this attached document with some other ideas/suggestions, and a website that suggests there is indeed a GM-designed re-learn procedure gm drive by wire cleaning procedure.pdf
