Need some opinions
  • Need some opinions
    Keep getting code P0131 code for O2 sensor. i hav replaced the sensor numerous times and keep getting the "lean" error on my 03 3400. it idles rough and i cannot figure out wtf is causing this code... i get a rotten egg smell every now and again too... any ideas guys?
    understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
    cat is bad.. Bad Kitty!
      can a bad cat can cause the idle to float around?
        Also does a cai on the 3.4 usually cause a lean condition? or is it something else?
