Cutom 3.1 supercharged
  • Cutom 3.1 supercharged
    I am using the TGP code as a base for engine management. I am editing the code with GMPCM. I just wanted to know what kinds of changes need to be made to the TGP code which is for automatics only so that it can be used with a standard trany. I was also do not have a/c and the TGP code has a/c should this be removed? do I have to remove all the stuff relating to the automatic? is there a problem with fuel decel cut? if I cut this stuff out will the bin file still work?
    Thanks for the help
    3.1 M62
    I remembered TGPilot and Mick working on the TGP chip to try and convert it over to a 5spd. I have the BETA code....when it was just released for a SHORT time. I could email it to you if you like to see what they did. I think they changed more things though since then.
      5 speed tgp code
      If you could send me that code that would be amazing! If anyone has the newer version of the 5 speed code that would be even better!
      3.1 M62
