I can scan - but I can't log! Tunerpro..
  • I can scan - but I can't log! Tunerpro..
    For some reason, I have all the sensor data being displayed in real time, but when I log, tunerpro is only recording half the sensor data. The rest is 0's. It shows up in the real time sensor info, so I don't know why it's not being logged??? Any ideas?
    Okay now, that's enough of that.
    I think you'll have to send it to me and let me... inspect it...
    I'll give it back when im done!
      LOL I thought you brought up my thread... Let me guess.. 3100 OBD"1.5" right?
      Read here
      But yeah from what I believe it's a TP bug when it saves the data stream, things are missing/corrupt. It appears it's only on the 3100 stuff as the code for the datastream logging hasn't changed in years I was told. BTW I have modified your definition to include a lot more things. I have the latest version on my laptop.
      I have made a definition file for ScannerPro (which is in beta) complete with nice analog gauges etc for the 3100 and it will record and play back just fine. But there is no .csv export yet. Moonwell has a online program that can accept the log file from ScannerPro and convert to .CSV but RPM is not being translated right last I used it on mine.
      I even posted about it on the TP forums. See Here.
      Maybe we could bug him in the TP bug section and get it finally resolved? ScannerPro is nice but I'd like to have CSV's too.
      Let me know if you want my definitions for SP/TP.
        bah... that sucks.
        So you're telling me there's no way to make complete datalogs?
          not with TP. Unless we get that bug fixed.
          ScannerPro works but like I said it's in beta so no csv export yet. But Moonwell's thing can make .csv just a few things need tweaking like RPM and IAT to be accurate and it would work then.
            tweaking? Is it something I can do in excel? It is just a conversion problem?
              Moonwell needs to tweak this: http://efi.moonwell.com/scannerpro/testing.php
              Although I have not tried it in a while he may have messed with it more. You have to run ScannerPro log through it and then it will give you a .CSV to download.
              If you want the ScannerPro definition to scan just let me know.
