converting map volts to kpa
  • converting map volts to kpa
    how do you do this for a 1bar map?
    '94 Cavalier Z24 3400 Turbo 5 spd
    I would guess use a datalog? I don't know if I have any old ones or not.
      hmm yea i dunno, youd have to figure out how to convert 0 to 5 volts into 0 to 255 dec lol
      cuase all i know is .369 * (0-255) + 10.35 = map in the tunerpro/scannerpro
        its showing up volts in the datalog
          just change it to
          .369000 * x + 10.35
            Originally posted by sil View Post
            just change it to
            .369000 * x + 10.35
            using that formula 1.8 volts is 11kpa??
              factor should be 0.369000
              offset should be 10.350000
              all .ads files i have seen that have the map in kpa, read 10.35 in the display when not connected lol
              they all use that formula
              think its got sommin to do with real atmosphere and then what the intake sees
              cant exactly remember why
