Nitrided 26O Comp Cam with lifters for 3.4
  • Nitrided 26O Comp Cam with lifters for 3.4
    Hi all,
    As some of you may know I have a 3.4/3500 setup in my 95 camaro. It has a mild 260 Comp Cam that I need to upgrade to take full advantage of my aluminum heads, ls6 valve springs, and soon to be boost. It has been through the additional nitride hardening process which alone makes it an expensive cam. I will include the cam and lifters with the lifters labeled for each individual lobe of the cam(necessary for flat tappet cams).
    TL;DR- 260 Nitrided Comp Cam with lifters for 3.4 V6
