FS: Custom KONI coilovers.
  • FS: Custom KONI coilovers.
    these are for the 99-04/05 alero and grand ams. may work on other cars. im more familiar with the alero and grand am, so if you know your car can use them then hey! :P
    one of a kind, only set like it! (to my knowledge) currently installed on the car. they were rebuilt 5 years ago, installed on the car, and never saw the street. so basically sat in the garage on the car for years....... (still has not seen the street) recently bought an alero with these on it... do not want, sadly I do not know how low or high they go. they are set at a good height now and honestly wouldn't even adjust them to go any lower or higher. just depends what you are looking for..
    heres all the info I know on these..... $1200 OBO.
    - Struts started as GM factory.
    - sent in to true choice motorsports in ohio for rebuild.
    - gutted the struts and put Koni adjustables in place.
    - Koni 8611 double adjustable inserts.
    - Uses stock bearing plates.
    - 2.5 inch ID Eibach race springs.
    - 350 lbs of pressure to compress front springs 1 inch.
    - 200 lbs of pressure to compress rear springs 1 inch.
    - Sleeves and top mounts are anodized aluminum.
    thanks for looking.
    2001 GLS 3400. F40 6 speed.
    Mods: F40 6 speed swap. Pacesetter Headers. Flowmaster Muffler. Cold Air Intake. MMS Engine/Trans Mounts. MMS Stainless Allen Header Bolts. MMS Header Gaskets. MMS PP UIM/LIM. MMS No Cat DP. Prosport Gauges. AEM A/F wideband. 8000K HID's. LED Fog Lights. 18" MSR wheels. Nitto Tires. Lowered. Baer Brakes. SC/T Spoiler. Sparco Racing seats. Harness Bar w/ 4 pt harness. A/C Delete.
