Getrag 284 Setup
  • For Sale : Getrag 284 Setup
    Alright, lets try this thread again without a bunch of debate on what trans I actually have. Ill start off, I know it's a 284 just like I previously posted for sale. It says 284 right on the trans tag and I pulled it myself from a 92 GTP.
    IIRC mileage on trans is 127K. Engine in car was junk. Trans shifts easily through all the gears.
    What's included?
    -Trans (127K IIRC)
    -Tail shaft to engine block bracket. Slightly cracked, easily repaired. I haven't seen many uncracked.
    -Repaired/modded trans mount. Poly filled. Looks nice
    -Shift cables, has grommets in place. Move freely, comes with new "Nunzi Mod" bushings, washers, clips
    -Shifter and mount clips, round style GP. No shift knob
    -Firewall plate, modded auto unit. clutch MC fits nicely and securely
    -Column/Pedal bracket assembly. Proper 5-speed unit
    -Master Cylinder
    -Slave Cylinder
    -Stock line, but comes with Pinlock to -3AN fittings so you can use a prefabbed braided stainless hose instead of the stock line and crappy accumulator setup. Summit sells the prefabbed hoses for aboot $20. Not sure of length needed
    -NEW (Not Reman) flywheel. Has been bolted to my LX9
    -NEW (Not Reman) Axles, both sides with stub shaft
    -Trans to block bolts
    -VSS and reverse switches in trans with pigtails.
    -Has a dipstick (thanks Nunzi!)
    You will need a clutch set and flywheel bolts. Nunzi says Auto bolts wont work as they are a bit too short. I bolted the flywheel to my LX9 with the stock LX9 bolts and they seem to engage plenty of threads. AFAIK, LX9 bolts are not the same as LQ1/3x00 thread pitch anyway so I won't be including mine.
    Will need the trans fluid, and I recommend new axle output shaft seals. They are less than $20 for both.
    And that's aboot all. Add clutch, flywheel bolts, 2 seals, fluid, and enjoy shifting. I'm looking to get rid of it cause well, it's just not gonna fit what I really want. Time to realize a 284 isn't realistic for my goals.
    Asking $900 OBO or TRADE
    Got a decent running not rotted out spare W-body or other car? I'll trade straight up for this setup. I'm also willing to trade for other stuff, just ask!!
    Any questions, lemme know. I can get pics up upon request. Nothing special, tis gonna look exactly as I described
    -Bob
    92 Cutlass Supreme Convertible DD, rolling on 19's
    90 TGP LX9T/4T60e Project, rolling on jackstands
    08 Kia Specta SX Family Hauler
    -Bob
    IIRC if you used a 90 degree fitting on the trans end, you would need around a 18-20" line.
    Whoever buys this for sure would want to get manual flywheel and not auto flexplate bolts, like mentioned above. The flexplate for an auto is very thin compared to a flywheel.
      No shift knob?
        Thread pitch has to be the same. Otherwise the flywheel bolts that came out of my LQ1 crank would not have threaded into my LX9 crank.
        1994 Corvette
        LT1/ZF6
        2006 Dodge Dakota 4x4
        3.7/42RLE
            Ok, I wasn't sure on the pitch. I had a bunch of 3x00 flexplate bolts so I thought, but they turned out to be L67 ones.
            IIRC The bolt needed is a M10x1.0 and aboot 20-22mm long.
            No shift knob, the one that was on it looked like a wolf chewed it up.
              Willing to take $750 for everything,
              I can store for around 6 months until it can be picked up. Would save alot on shipping obviously,
              Located in Lorain, Ohio 44055
                I would be willing to buy some of your parts
                - trans mount with pollys
                -Shift cables,
                -Master Cylinder
                -Slave Cylinder
                - Axles, both sides
