95 3.4 DOHC wiring harness and t460e
  • 95 3.4 DOHC wiring harness and t460e
    I have a full motor 3.4 DOHC, trans, wiring harness, and comp for sale.
    126700 miles or 204 000 km on motor, new torque converter and a used but good working t460e also other bits ... message if you are looking for something
    still have the 4t60e? what year is it from and where are you located?
      its from a 95 and I am in charlottetown
        Hi,
        Do you have the engine wiring harness + engine to transaxle mount bracket (this bracket is black and it is like a circle bolted to trans. case)?.
        How much to Miami 33172 zip?.
        Thanks,
        Denis V.
          I do have both I will have to check the weight and get back to you on the cost
            O.K.
            How much if you add the following little parts (if available)?:
            1.- Water inlet housing/pipe to water pump (where the lower radiator hose is connected to).
            2.- Two rear upper intake plenum supports ( 2 pieces like a "S" bolted from rear/right head to upper plenum).
            3.- Steel fuel lines (methalic fuel lines from fuel rail to fuel hoses).
            4.- Two or Three lower intake manifold bolts (rare bolts with isolator included).
            (I can pay via Pay Pal in US dollars, but all payment methods are possible: only email-me)
            Thanks,
            Denis V.
              if you still want the parts send me you email address and I will fire the info your way
